Good Afternoon friend, thank you for your post!
I see that your Frigidaire freezer is making noise and you have recently defrosted it, but your freezer is still making the noise. Your freezer will make certain noises which are normal operating noises for the freezer.
The compressor is a high efficiency so you may hear it during start up and while running. Additionally, refrigerant circulating through your freezer can make a tapping sound or even a gurgling noise. I hope this has been helpful. -Matt
SOURCE: Kenmore Upright Freezer Model 2539252110
constant clicking, sounds like a compreesor trying to start itself, you might geta way with replaving hte starting device for compressor, sometime s a bad compressor will burn out a starting device, checl your warr papers, most compressors had afull 5 year warr
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
SOURCE: i do not have a manual so I don't know how to defrost it
Look for a white plastic plug in the floor of the freezer, about the size of a quarter. Remove that. Take the front grill off and feel underneath for a plastic hose (one end connects to the drain hole, the other end you can catch defrost water in using a shallow pan). Use a hair dryer to melt the frost (with the freezer unpluged)
SOURCE: I have a 4yr old 13.7 cubic upright frigidare
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
SOURCE: 13.7 auto defrost upright freezer, runs all the time.
nop its not normal but it will make no further problums if u turn it Off manually after 6hours running (for 30mins), and if u wanna completely solve that prob contact the warranty provider and change the Thermostate.
but i suggest if the friedge have expire to his warranty, dont take any tension it will work properly through this condition (if u manually OFF and ON it regularly).
take care.
for further assistance....
[email protected]
shafky
