My iphone has ben inadvertanly locked by passcode, the optus folk have said I have to delete everything through iTunes but I cant get action as I dont have an apple ID or password. plase assist? I dont think I have had an apple ID
Hi, there!
You can easily create your own Apple ID here: https://www.apple.com/icloud/setup/
But it seems that your particular iPhone is locked via the former owners Apple ID, which gives you no option other than contacting him and asking to delete this iPhone from his iCloud account.
Best regards,
B
SOURCE: can;t use itunes unless enable iphone via passcode
Enter DFU mode by holding the sleep (top button) and the home button for 30 seconds. Then plug your phone in, iTunes will recognize your phone and will ask you to restore it.
Happy Hacking
SOURCE: iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
SOURCE: iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
SOURCE: Iphone disabled, can't connect to itunes
read detailed solutions on "forgot iPhone passcode and iPhone disabled" from http://goo.gl/z5CNo
