Not functional
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
SOURCE: What does the Functional Code SC 302
This code refer to main charge.The charge corona leakage.Check the charge corone wire and grid (clean or change),clean the corona unit input contacts,check the main charge power pack and the high voltage control board.Recomand to change the corona holders,wire and grid.To reset the error code Turn OFF the power switch unplugged wait 10 sec plugged and turn ON the switch.
SOURCE: please solve this problem Ricoh 7650 Code SC 902,
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
SOURCE: how can i solve error code sc:302 in ricoh Aficio
You should have a service technician take a look at your copier. SC302 is a charge roller current error, and it could be caused by a number of things, from a dirty charge roller to a faulty high voltage supply board.
In the meantime, try turning the machine off, unplugging it, and then plugging it back in and turning it on the see if the error message will clear.
SOURCE: functional problem sc 302 in ricoh photocopier
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
hello this is a charger roller problem replace your charger roller . call for service is good
