Windows 7. Current phone system is Time Warner Cable. One error said using wrong kind of phone cord. Same cord used for 8 years. Tried new one. No difference. Could the fact that cable provider has gone all digital and this is an old printer?
SOURCE: Setting up fax with modem
try to used the two conductor cable that came with the printer itself.
- at the same time ask for a filter from your phone provider
- the printer should be direclty connected to the phone walljack
- if you have all this kind of set-up you will be able to recieved faxes now..
send comment/feedback fo furthere troubleshooting...
SOURCE: HP Desk Jet 842C printer - need cable
Hi Debbie,
You should be able to use this printer with a USB cable. You can pick up a USB cable just about anywhere that they sell computer or printer equipment. Just tell them you need a USB printer cable. This is a standard item and no further description is needed.
The Driver for this will probably be a native driver, and you probably wont have to download a new one, but just in case, here is the link for the driver directly from HP.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=60426&
Good Luck
SOURCE: Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
SOURCE: hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
SOURCE: I have just tried to install hp 7280 all in
Does the printer print its own self test page? if so then check solution center if it states that there are no devices detected or that you need to insert the disk and complete the installation it means that the drivers did not install properly. if you havent already download the full feature software and drivers from hp and uninstall the previous installation that was attempted.
