Legend - When I plug it in, it does not charge at all. The meter shows no movement. The 4 fuses at the rear are all ok, and pressing the reset button at the rear does nothing.
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
SOURCE: Batteries fully charged on pride legend fuses,
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
SOURCE: i have a pride mobility a scooter, maxima, when
When mine does this it means she is not fully in gear. Try manually moving it back and forth a few inches and see if it clicks in.(Like moving the seat back in the car and it doesn't quite click in.) If it doesn't work take it fully back out of gear and try again. Mine is a pride victory 3 wheeler, to check the exact specs on yours follow the link below for a pdf of your user manual. See the bottom of page 34, (Troubleshooting)
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Maxima%20Owner%27s%20Manual.pdf
Hope this helps:).
SOURCE: Where can i find an
I have downloaded a service manual for your scooter on this site.
You can e-mail me and I can send you a copy.
[email protected]
