Look for a WPS (WiFI Protected Setup) button or a sticker with a PIN # on the router.
http://documentation.netgear.com/wgr614v9/enu/202-10308-01/index.htm
http://documentation.netgear.com/wgr614v9/enu/202-10308-01/WGR614v9-10-1.html
SOURCE: protection on my Mac
Given that you have setup the Internet connection on your router, encrypting the wireless security will be fairly easy for you. Just follow these steps.
1. You should use you PC or MAC that is connected directly to the router via an ethernet cable. You can use PC or MAC, which ever is connected directly to the router (Connected thru cable not wireless).
2. Open Internet Explorer / Firefox (PC) or Safari / Firefox / Internet Explorer (MAC), then go to the address bar and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Leave the username blank and type admin as the password (**If that will not work, (Enter admin for both the username and password)
3. You should see the Setup page shown below :
4. Click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use your name or last name, or any name that you would like, because that will be the name of your wireless network, that will be the one that your wireless computers will detect) then click on Save Settings and then Continue when the Settings are successful dialog is displayed.
5. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 64 bits 10 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. It Will generate 4 keys (Key 1-4). You will use key 1 as your password.
6. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed.
7. Now let your wireless PC scan for available wireless networks, find the name of the wireless network that you have specified earlier for SSID then connect to that network. Of course since the network is password protected, it will ask you to enter a password, this is time that you will enter the network key (Key 1 - password).
SOURCE: how do i protect my unsecured home wi-fi network?
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
You want to secure the wireless network.
Is there any computer connected to the router with the
Ethernet cable?
If not then you will need to connect the computer to the
router with the cable.
Check the IP address on the computer. Open the router set up
page.
Once you open the set up page, you will find the option to
make it secured
Click Here for step by step instructions
SOURCE: is there a Wi-Fi Protected Setup button on the
nope to old it does not have wps i believe it will only do wep, open and wpa.
Testimonial: "Thanks starrtech for your quick response!"
SOURCE: nintendo wi-fi connection setup
Turn on the Wii...
click the icon that looks like a house (home) on the Wii remote...
Go to the settings > Internet > connection settings > connection2 > wireless > look for an AP in range...
enter security settings (enter your password)...
you will get a message..."did you wish to save"...select yes
you will get a message that says "testing connection"...success...Done...!
Turn off / Disable wifi in the laptopTo Enable WPA Security in the wireless network
- - Hardwire the computer and router
- - Open the router setup page ( http://192.168.2.1 )
- - Click wi fi Protected setup on the left side
- - Scroll down a little and you can find the router PIN
- - This is the number that you need to enter in the device
If you're using your HTC Wildfire for the first time, you can easily select the Wi-Fi network you'd like to join using the setup manager.
When you opt in for either Mobile Network or Wi-Fi, or just Wi-Fi, the Wildfire will by default try to connect to a Wi-Fi network near you.
Select the network you wish to connect to, enter the password if required and you're set up.
If you want to change the settings, or set it up for the first time, you can do this through the Settings menu.
Note: If you're attempting to access a network-based page or app, you may be required to set up a new Wi-Fi connection. When prompted, select the option to set up a new connection.
If Wi-Fi is turned off, you can now turn this on by ticking the box in the Wireless & networks menu.
