Your
Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
