Question about Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave
Microwave runs when door is open
When the door is open, the unit continues to run ... and shuts off when door is closed.
  • Official Brand Answer
  • 2,267 Answers
Hey friend, thanks for your post!
From my understanding your Frigidaire microwave is running when the door is opened. I have identified a few possibilities could be the control panel or your door. Since it could be any one of these underlying issues I would recommend having a professional come and properly diagnose your appliance. -Matt
Posted on Sep 25, 2014
6ya staff
SOURCE:
Philip
  • 949 Answers
SOURCE: Frigidaire FMCB115GC Microwave Oven wont stop
The only parts that are available for this unit by model number are the tray inside and the feet on the outside.
If you were adventurous and found a way to take it apart and remove the door switches you might be able to match them up at an appliance parts dealer but short of that it sounds like a lost cause.
I know that is not what you want to hear, and I as well do not like being the bearer of bad news.....
Posted on May 13, 2010
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: My microwave is on when door is open and shuts off
That's almost certainly a bad door switch or switch mount.
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Your model's service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jan 29, 2011
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Firgidaire Microwave fan runs when door is closed.
I'd bet the fan and / or turntable also run when the door is closed, which means you have a shorted relay on the control board, which can be repaired for $39.95 in most cases. Details are here.
Posted on Apr 29, 2011
archaeology
Archaeology
  • 662 Answers
SOURCE: when opening microwave door, microwave is running
Your microwave oven's door interlock switch has failed. This is the switch that is supposed to shut off the microwave when the user opens the door.
Since parts for small appliances are unavailable (replacement parts are only available for major appliances), you'll have to either live with it or try to fix it by finding a similar microwave in someone's trash, and using that unit's door interlock switch...
Possibly a popsicle stick (or other safely non-conductive article) can be pushed into the appropriate
contact point?
Posted on Sep 10, 2011
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: frigidaire microwave plmv168cc1 makes humming noise when door closed
Chances are that the secondary (cook) relay on the control circuit board is shorted, meaning that the oven is actually cooking any time the door is closed.
You can test that by putting in a cup of water, shutting the door, and letting it go for about 30 seconds, then checking the water temperature.
This is dangerous, and can lead to a fire, so please unplug the oven until it is repaired.
The relay can be replaced for far less than the cost of a new control circuit board.
Posted on May 31, 2012
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 24, 2015 | Amana Microwave Ovens
Roper Microwave fan won't shut off
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
How do I get my emerson microwave to turn off after the timer is finished?
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 20, 2014 | Emerson Microwave Ovens
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Dacor DMT2420 fan, light and turtable motor run continuously when the door is open. I have unplugged the unit to reset it with no help, another on-line forum expert suggested checking the door switches...
If the cooling fan, light and turntable run continuously when the door is open, but not when it is closed, your secondary interlock (bottom door switch) is shorted (always on).
Even if it's shorted, the actuator button (usually red) will still move up and down when you open and close the door.
It will need a new door switch.
See the service manual here. See our file on door switches here.
Jan 04, 2010 | Dacor DMT2420SS Microwave Oven
Model 565.66400, still runs when door is opened?
if unit runs with door open then one of the door switch is stuck closed.there are 2 door switches and they could be assesed by removing the control panel.disconnect wires from top and bottom switches and chkf for continuity.they should be normaly open when the door is open and closed when door is closed.one of them will closed even when door is open.replace that bad one.
Aug 11, 2009 | Kenmore Microwave Ovens
When we close the door the motor keeps running.
This just started happening on my Kenmore microwave because the door latch broke off.
Mar 10, 2009 | Samsung SMH7178STD Microwave Oven
Frigidaire 1.6 Cu. Ft. Over-the-Range Microwave Logo
305 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
