Range was set up for natural gas and am change it to lp gas. When I turn in the spud I could not figure out how to get into the spud. Reach in and change three but still have to change one.
Parts diagram from sears.
AMANA Slide In Gas Range Parts Model ARGS7650SS P1130764NSS
Amana Product Literature Search Results
SOURCE: I cannot seem to get
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
SOURCE: Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
SOURCE: How do I get scratches off the smooth cook top on my range?
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on
stainless steel, glass cook tops, polished granite marble and more.
DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is
perfect on
stainless steel, glass cook tops, polished granite marble and more. .
We buy DeBruce at debrucepolish.com.
This IS the answer for cleaning an maintaining. Will not remove the heavy scratching in glass.
