Do you have a picture of how to take glass top off?
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone
burners - the burner power indicator light stays lit whether the heat
control knob is on or off, there is no heat coming from the burner on
or off. You pulled the burner from the receptacle and one of the tabs
broke off and stayed in the receptacle. You removed the tab and made sure
no pieces remained in the receptacle then bought a replacement burner,
no change. You put the replacement burner in the back burner of the same
size and had heat within 10 seconds. You changed out the burner with the
one that had been in the back of the range, no heat. As long as the
breaker to the range is on the power light stays lit but no power to
that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
SOURCE: REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
SOURCE: have a whirlpool electric glass top stove
You must replace the burner switch for that burner.
SOURCE: Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
It is the infinite switch (burner switch) located in the console,.
