Bunn Commercial Bunn My Cafe Pourover Single Serve Coffee Maker Logo
A
Anonymous Posted on Sep 22, 2014
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
IT WILL NOT DRIP INTO CUP. IT MAKES NOISE BUT NOT LIKE IT USED TO DURING HEATING PROCESS
fixyamanager
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 30 Answers
  • Posted on Sep 22, 2014
fixyamanager
Contributor
Level 1:
New Friend:
Cheetah:
Answers
30
Questions
0
Helped
20387
Points
56
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
2answers
Coffee maker not working
Here are some of the most common problems that can cause your drip coffee maker to stop working:
  • The power cord or on/off switch can go bad. In either of these cases, it's best to get a pro to replace it or buy a new coffee maker -- replacing it improperly can lead to a fire.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
There are two problems that are nearly impossible to fix:
Failure of one of the heat-sensitive switches
(This is The coffee maker's temperature sensors)
Failure of the heating coil:
(This is the The coffee maker heating coil)
Because it's nearly impossible to get replacement parts, you probably have to buy a new coffee maker if one of these problems disables your machine. Now, when you make coffee tomorrow morning, you can do so with a new appreciation for exactly what's happening inside.
Goodluck,
Please don't forget to rate the solution
Water heats. blue lights work. only drips come out. put vinegar in. 10 drips come out.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
1helpful
Coffe maker turns on and drips a little into the filter then stops. The coffee grounds are still dry and it doesnt make coffee. The plate is hot. The coffees not.
First check that the thermo switch is not opening at to low a temperature. Can you measure the hot plate temperature? It should be over 180 degrees. If not then it the thermo. I would replace the Thermo switch, These are not soldered in because of the heat application. You must use mechanical connections, such as crimp splicing.
The other option is that the water can't flow into the heating element Or from the element. There is a one way value in the feed path that needs to be checked that it is functioning. You can test it with straws on units that do not have a removable water tank. locate the water drain in the tank and take the straw and place it at that drain and blow hard. You should hear air flow through the unit and out the drip tank. You need a far amount of seal at the bottom for this to work, I built a ridged tube with a cup on the bottom. This will not work if there is a bar grid were the water is pored.
Good luck.
Am looking for an instruction manual for a Faberware 10 cup coffee maker
Hi, Farberware only makes 4-8-12 cup coffee pots and they all use the same manual. I have some. contact me through [email protected]. Ron
1helpful
2helpful
Just stopped working water will not heat up and drip
Heater element burned out it uses the same element to heat the plate and coffee water. They won't sell this part in fact they use tamper proof torqx screws to keep you away from it. Get a new pot!
10helpful
3answers
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Need owner's manual for a West Bend 57870 coffee maker
Manual Not Listed On Website, but Information on Coffee Amount is.
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=2318&secid=54&linkon=category&linkid=21
Coffee Amounts
How much coffee should I use?
4-Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. You can adjust the amount to suit your personal preference but DO NOT USE MORE THAN 2 TABLESPOONS per cup being made. If more than 2 tablespoons per cup are used flooding of the basket may occur.
10 and 12 Cup Quik Drips - We recommend using 1 tablespoon automatic drip or ""all grind"" coffee for each cup being made. If making less than 4-cups of coffee, add an extra tablespoon of coffee for better flavor. You can adjust the amount of coffee used to suit your personal preference.
Top Bunn Commercial Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Bunn Commercial Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
