Washer wont start. The door is in fact sealed tight but it won;t reflect the "door lock" button lite up therefore it does not start. Any suggestions
The vent was stop up well had a mouse size fur ball in the vent pipe work after removing it
Replace the door lock, takes about 10 mins. Just replaced mine. Ordered it from Amazon for less than 40.00. You take the top off and unscrew the lock from the front. Reach in and pull up, unplug old one, plug in new one. put new one back in the holes, screw it in tight. Put the top back on and your done. Don't forget to unplug it before you start.
SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
SOURCE: my Frigidaire affinity washer doesn't
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
SOURCE: Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
SOURCE: fridgaire FTF530fs3 door lock buzzing and not
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
