I would like to remove the door and see if i can get it to close properly but I don't know hw to remove the door
This is quite often caused by several factors ...
1] Worn door seals [REPLACE them] ...
2] Rusted door PINS [in older units] and/or worn PLASTIC BUSHES that support these pins [REPAIR or REPLACE them] ...
3] MISALIGNED and/or WARPED door [mostly in older units and/or if the kids hang off the door (especially young children) over an extended time ...
MOST doors are easily removed [but some are quite heavy and/or have electrical wiring/water lines etc. inside] so be careful. Usually you will need to remove the TOP hinge [screws usually under cover-plate] and then gently raise and lift-off the door from its bottom hinge pin. If you lift up the rubber door seal edge you will usually find a series of screws underneath. Just undo these to remove the inner shelf/door lining to replace the door seals. You can buy ready-made replacement seals from most major manufacturers and DIY ... or you can get a tradesman to do this for you [companies such as "SEAL A FRIDGE" can be found in your local phone directory or on-line] ...
SOURCE: The refrigerator door does not close with a tight
adjust doors on the top of machine the hinges move to adjust and leval them. hope this helps
SOURCE: frost build up behind/inside back freezer panel
I have same problem, it usually happens after someone leaves door open
too long or after 4-6 months. I usually place two frozen milk jugs full
of water in the upper fridge and tape the upper fridge door closed at
night before bed so the kids don't open and let the upper food get
warm., Unplug the fridge and open the freezer and remove all drawers
(place excess frozen food in freezer in garage) , leaving the freezer
open with a towel in the bottom to catch the melting water from the
back panels inside and the next morning wipe the fridge bottom clean
and plug it back up and replace everything. I hate that I paid so much
for this fridge and have to defrost a couple times a year. However
found out too late to return back to the store. It seams like it should
have a cycle that heats the back plate every so often to warm and
evaporate the ice that collects, but I haven't heard or can't find
anything on that.
Kimsukie.
SOURCE: SubZero 690: Frost builds up on ice chute flapper door
you have a bad seal, Take a dollar bill and slide it in between the door seal and the frig. slide it up and down to see if if has drag on it. If you find places it dont touch loosen the screws and adjust the hinges till it fits tight. In some cases you might have to tweak the doors if they need it.
SOURCE: Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
