Iwas printing email when it started print both side. i went to tools and turned off two side printing but it still prints on both sides. what do i do to make it do what i tell it to do
SOURCE: printer leaves black spots on paper
The black spots mean you either need a new imaging
drum, transfer kit or fuser. You'll have to print some stuff and try to
catch where the black marks are appearing. Try this method (it's called
a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The
MOMENT the tail end of the paper disappears into the printer, open the
right door. Open the front doors and release the levers for the imaging
drum and the transfer drum. Carefully remove both pieces and examine
your paper.
You should find the paper partway on the
transfer belt but not in the fuser. If you see black marks here, start
with the imaging drum. Open the shutter that covers the sea green shiny
roller and look for marks on the drum (you'll see build up on the
edges, that's normal, you should not see any scratches, pockmarks or
toner on the center of the drum). If it looks clear, take a look at the
transfer drum for marks or cuts on it's surface. (note: the transfer
drum can be cleaned off with a dry lint free cloth, do not touch the
shiny sea green roller of the image drum)
If everything looks
good there, then likely the black marks are coming from the fuser. Let
the printer sit, turned off for about half an hour to allow the fuser
to cool. You can then remove the fuser and look at the rollers to see
if there is any build up or damage there.
If you are not
seeing any obvious issues with any of these parts, then start with the
imaging drum. If you know that any of these parts have never been
changed, then change them as they do have a limit to how many pages and
how much time they can be used for.
SOURCE: my printer keeps printing double sided when I need
You will need to change the printer settings in your computer. The duplexing / double sided printing is obviously turned on.
SOURCE: margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
