Question about Panasonic NN-SN661S 1200-Watt Stainless Steel Microwave
How do i fix error H98 on my panasonic microwave
There is code H98 which appears in the display window when I try to use the microwave.
    New Friend:
  • 9 Answers
This is a primary factory default code for a defective oscillator coil that cannot be repaired by the average homeowner without significant electrical training and precaution! It is recommended that you get a Panasonic repairman. While some videos exist on YouTube that seem to show simple repairs; comments show otherwise. Repair can be lethal. . Serious electrical hazard exists when attempting this repair. Do not attempt to do it yourself.
Posted on Sep 21, 2014
6ya staff
SOURCE:
Can't get it to cook. Stops and H98 pops up in window
thi code refers a broken switch intelock security take it to service
Sep 15, 2015 | In Microwave Ovens
Trouble code H98
H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
How do I fix the H98 error on my microwave
You haven't identified the brand, make or model but this may be helpful:
Newer Panasonic Microwaves have built in fault codes....
they look like H97, H98....
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used.
H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
NOTE:
Sep 09, 2014 | Microwave Ovens
Getting an H97 error code on a Panasonic micro wave, I believe I am having an inverter problem
NOTE: DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
Alternative way to troubleshoot oven with AC Ampere meter used. H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
Hope this helps.
Apr 28, 2011 | Vacuums
Microwave shows H98 problem. How can we solve it.
H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation.
NOTE:
Jan 01, 2011 | Panasonic NN-S541 Microwave Oven
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Turns off after 15 seconds..shows H98 on the window and wouldn't start.
NOTE:
Nov 04, 2010 | Panasonic NN-H765 Microwave Oven
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic NN-SN661S 1200-Watt Stainless Steel Microwave Logo
8,033 people viewed this question
Top Panasonic Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
