Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
A
Anonymous Posted on Sep 20, 2014
I have no power to oven or burners. Where are the fuses located
The burners first there was not power then a day later the actual oven stopped working, There is no power to anything. Where do I locate the fuses for each item
Ty Roshdy
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Whirlpool Expert 650 Answers
  • Posted on Sep 28, 2014
Ty Roshdy
Whirlpool Expert
Level 2:
Prodigy:
Answers
650
Questions
Helped
137026
Points
915
There would be no fuses in the stove itself. Try the house breaker or fuses to the stove.
3 Related Answers
marionbagget
  • 718 Answers
  • Posted on Apr 11, 2009
SOURCE: location of the fuses
GR448LXPQ
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GR448LXPQ
Click on your model number. Click on the diagrams in the left-hand side for the parts location.
A thermal fuse (9) is shown in the Chassis Diagram. You can check that and other diagrams for more.
Petroni0264
Bailey's Appliance Service
  • 222 Answers
  • Posted on Apr 29, 2009
SOURCE: Have small gas leak from oven burner oriface when oven is off.
The burner orifice you are referring to is part of the gas valve. You have two electrical connections on it, and the gas line to the valve comes from the pressure regulator.
Anonymous
  • Posted on Oct 17, 2009
SOURCE: The electronic oven control my whirlpool GS470LEM is blank.
I am having the same problem after a blackout yesterday. The range hasn't come on, even after we checked the breaker.
I have an old GE P7 stove with double oven The clock and outlet to plug in toaster oven stopped working.
A Toaster Oven is far to BIG a draw in amps for that plug and will have almost certainly melted a fuse if it has one. I have an early 1970's GE and there is a fuse panel behind the burners and below the clock and dials. The outlet is to plug in whisks and stick blenders only, mine sparks and arcs if I put a kettle in it.
https://www.google.com/search?q=ge+p7+stove+fuse+location
2answers
Bosch single wall ovens where is the thermal fuse located
Hi!
The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven.
To locate the thermal fuse, follow these steps:
  1. Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
  2. Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
  3. Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
  4. Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
  5. Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
  6. Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician.
Kind regards
Mar 12, 2023 • Bosch Ovens
Stove and oven won't turn on
Check there is gas at the burners then go from there .
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
Nov 22, 2009 • Ovens
2answers
Check the breaker to see if it is tripped turn it off and back on,
All my burners arnt working! HELP!!!
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
