My Dad has a Shoprider mobility scooter, which worked fine yesterday, today it does not go forward or backwards, it makes a continuous beeping sound when the ignition is switched on. The battery is charged, the lever is in the drive position. In freewheel there is no problem at all. Any ideas please?
SOURCE: User manual for shoprider madrid mobility scooter
Go to the Shoprider website and look for the scooter. It might have a different model name than the one you own. Get the name and click on the user manuals for the model that resembles yours (PDF file) and print.
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
SOURCE: Hi I have a shoprider cadiz .. when i try using
your throttle pot needs replacing. your thumb lever attaches to the throttle pot.
Testimonial: "Wonderful information Thank you ..before i read your answer i sprayed the throttle pot as you call it with switch cleaner Been great since .. "
Hi there I have a TE Gk9 shoprider mobility scooter and it's fully charged and the horn works but there's a beeping noise either from the front end or back end, no matter which position the back yellow lever is invited still continuously beeping,
