Transmission & Drivetrain for Acura RL Logo
F
Felix J Miranda Posted on Sep 20, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset a check transmission light on a 2007 acura tsx?
The check transmission service light came on while driving the car.
Ned C Cook
Level 3:
President:
  • Acura Master 3,433 Answers
  • Posted on Sep 20, 2014
Ned C Cook
Acura Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1437292
Points
9966
Hello, Have trans chked and repair if needed, including fluid and filter change. Temp or pressure sensor is picking upsomething unusual or is defective in itself.. Only way to get rid of light is to erase the code with a code reader.Once erased, if nothing is wrong the light just hiccupped. But it will return if there is a problem not resolved. Code readers are available at auto parts stores but too costly for single event use.A mechanics' opinion would cost a lot less. Get more than one persons input. Don't let something you don't feel you know enough of scare you into unnecessary repairs. It could be something as minor as slightly low on trans fluid. Many tfalse alerts. Good Luck, -Ned-
Jose Mendoza
Level 2:
Sergeant:
  • Expert 199 Answers
Jose Mendoza
Expert
Level 2:
Sergeant:
Answers
199
Questions
7
Helped
66162
Points
527
Here we go my friend, hope it helps!
Problem with 2007 Acura TSX I bought an acura tsx
take it to a frame shop, or top body shop..
first get it unbent.
brakes degrade, parked in the rain, for long periods. they rust.
My ACURA TSX has 42,000 miles. The dealer says I need service to the tune of $550. I find this hard to believe. The car has no problems and I don't drive it rough. I would love some advice on this!...
Don't take it to them.
At only 42000 miles, there shouldn't be anything on the vehicle nearing that cost even to replace.
For service under a regularly scheduled maintenance, a tire rotation, new oil, spark plugs, brake cleaning, all fluids including the transmission, and even throw in all new exterior lighting...wouldn't cost nearly 550 dollars.
2helpful
2answers
How to reset service light on 2007 Acura MDX
The full procedure how to reset oil service light Acura MDX. After an oil change, if you like to reset any maintenance oil light for Acura cars. Or any error which appears on the display.
http://resetservicelight.com/reset-oil-service-light-acura-mdx/
1helpful
How do I reset the service alert on my 2007 acura tsx?
You can the info you need here also a little of any thing you need to know. http://aa1car.com/
The shifter light is not working what do i need to take apart to replace it?
Are you talking about the light that tells you what gear you are in? As in Drive? The reason I ask is it could also be your transmission giving a fault code which is the reason your light is not coming on and not just a burnt out lightbulb. I would call your Acura service department and ask them for sure but check on that before you assume it's just a bulb.
Good Luck
How do I reset the oil life indicator on my Acura TSX 2006
To reset MAINTENANCE REQUIRED light, turn ignition off, press and hold the SELECT and RESET buttons. Turn ignition on and hold buttons for 10 seconds until indicator resets.
2helpful
3answers
Oil reset light
how do i reset the oil light on tsx
Setup the wach after to make service
with key off hold the select/reset button on speedometer, turn key to on position and wait until the maintenance light flashes ,start car and this should reset it -Jeff please rate
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
