Power source is 14-2 110 going to living room outlets
Pretty easy if you can get the wires from the existing wall outlet. Just run a wire from existing outlet to the where you want the new light. Install inside an approved ceiling electrical outlet box and then run another wire to where you want the switch or switches. If you go to home depot or the library you can look at the books with diagrams on how to wire it. You can skip the wall switch if you use a light with a pull chain.
Testimonial: "sorry peter,i don't get it.maybe I should run downtown,someone at the depot probably will refer me to a 100. dollar an hour electrician or I can drive another 25 miles to a library..i believe its a middle of the run light,with power source in,than to a switch from switch to outlets so they have power?"
