Question about AEG Dishwashers
My AEG Favorit 675 is getting stuck in the rinse aid cycle. It sounds like the pump just keeps on trying to drain. I may also be that the water is not coming in for this part of the wash only. Also wh
Also water fills the bottom tray sometimes and the drain motor runs permanently until I tip the dishwasher up and drain the tray.
    New Friend:
  • 30 Answers
Have you tried cleaning you filters. this sometimes stops the machine from draining
Posted on Sep 20, 2014
Testimonial: "Yes, they are clean. I think the water is not filling when it should as the machine is empty when I open the door. It does fill fine at the beginning of the cycle though. I think the pump noise may be the main pump trying to wash the rinse cycle, but the machine is empty."
6ya staff
SOURCE:
AEG FAVORIT DISHWASHER, PUMP KEEPS GOING WHEN TURNED OFF, UNLESS TURNED OFF AT MAINS
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
Nov 02, 2017 | AEG Dishwashers
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
My AEG 18 in. Favorit 54750Vi has stopped working. It sounds as though it's going to start normally then starts to beep. When I open it the 'Rinse and hold', 'Normal 65*',and 'Intensive 70' indicator...
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
Oct 12, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
Aeg dischwaher model oko favorite
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG Favourit 446
Our AEG dishie also tripped the light regularly. Turned out there was a water leak by the motors and the cut off device wasn't working and when the water filled up too much it tripped. Move the dishie and if water 'sloshes' out the back, then you know the problem, or if not, take the side panels off so you can see underneath, if there is water at the bottom of the machine. Hope you find the problem.
Aug 11, 2008 | AEG 24 in. Favorit 40310 Free-standing...
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
Smeg dishwasher
my hotpoint dish washer aquarius is 4 years old leaves a sandy grit all over dishes water not spraying the top,done all the usual stuff run out of ideas
Mar 09, 2008 | Dishwashers
AEG Favorit 420 Freestanding dishwasher
i have 4220 and i replaced the drain pump, fixed, located underneath to right at the front
Dec 26, 2007 | AEG 24 in. Favorit 40310 Free-standing...
Dishwashers Logo
319 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Mark Brooker
Level 1 Expert
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
