Example: 85.00 x 10% x 20% x 19% x 1% x 43% x 1% x 1% x 5%
SOURCE: Percentage button!!
The Casio MS-80TV requires you to input percentage calculations differently than other calculators. To calculate percentage change addition for this example, you must input "12000X20%+", for subtraction, you must input "12000x20%-".
SOURCE: calculating percentages
how can i change or fix an exchange rate in Xasio JF - 100TE calculator
SOURCE: Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
SOURCE: How change percentage (tax) rate on Casio-1100TV?
FINALLY figured out how to change the tax rate! Press AC. Press and hold the Rate Set (%) button UNTIL THE CURRENT TAX RATE IS DISPLAYED. Enter the new rate you want (such as 7.5). Press the Rate Set (%) button again.
