Vacuums Logo
B
Bill Norberg Posted on Sep 19, 2014
Where does the power light clip on to on the kirby legend 2 1984
I took it apart and when putting it back together all went well but I can't figure out where the power light clips on to
FSO34688
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Feb 02, 2015
FSO34688
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
6738
Points
98
The light clips into the top and mid point of that black on off switch.
It is the biggest pain to see those 2 entry terminals on the back of that switch and the only way is to cut those white tie wraps that go around the light wires to the pot metal frame to get just the extra amount you will need.
A good light source and a sharp pair of needle nose pliers will be needed to push the 2 light plugs into that main black switch.
I used to dread that when replacing those entire switches until getting used to it.
Another note that if you get the motor wires reversed when plugging them into that switch......it reverses the motor and will blow instead of suck.
Hope this helps!
William R!
5 Related Answers
Anonymous
  • 112 Answers
  • Posted on Jan 14, 2008
SOURCE: Kirby Heritage 1HD
this site may help
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
good luck :)
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Jun 28, 2009
SOURCE: It's been awhile since I have used my shampoo
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Anonymous
  • 348 Answers
  • Posted on Oct 17, 2009
SOURCE: How do I change the outer bag clip?
I had a Kirby Classic and I had to slide off the clip.Don't rate me if this doesn't work.
vacwater
  • 175 Answers
  • Posted on Jan 01, 2010
SOURCE: replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Roger Potts
  • 694 Answers
  • Posted on Jan 30, 2011
SOURCE: i have a kirby sentria. vacuumed up my son's
Take the front off the vacuum and check inside both the front portion and the canister for additonal clogs. Sometimes something will get caught in the impellor, causing the motor to overheat. Since there's little suction and the smell, I'd guess this is what happened.
Indicator light comes on but sweeper doesn't run.
it sounds like the motor is dead. The Light and the motor are wired differently so it is quite possible that the motor is dead and the light still works.
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 • Vacuums
Replace wheel axle on my kirby g3 vacuum. have a
5helpful
2answers
It's been awhile since I have used my shampoo system on my Ultimate G series Kirby. Well, as instructed I took it apart and cleaned it. Now I can?t figure out where to put the ?screen cap? and ?sponge...
Marci
2helpful
TechDrive power assist fell off
See if THIS helps.
Not sure how far you went disassembling the unit so here are a few more useful articles that you may want to see:
How to connect wires
How to get the transmission installed.
Rocky
2answers
Kirby Legend II
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11558&thid=818960
Kirby Legend II
Posted by smokey 1 on July 22, 2008
Hello, Help please, Using my vacuum, turned it off briefly, then went to turn it back on and it would not .I checked plugs which were both fine. Motor is strong, impeller is fine. The light comes on near the button to turn it on however it's not doing anything. Switch maybe? Just a guess. Thanks for your help! Alice
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It can be only one of 2 things, either it could be the safety switch or the foot switch and they would have to be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
