The fans are there to cool the engine but once you stop the car the temperature is not being cooled by movement of air and water circulation via the water pump so the fan cuts in for a short time to stop the temperatures causing damage. when driving the air cools the motor enough to keep it a t the right temp no air movement no cooling.
SOURCE: how to remove the ignition switch in a 1993 Jeep Cherokee?
The ignition switch or the key cylinder?
you need to remove steering wheel and you will see how its done once you get inside
SOURCE: blower fan just stopped on my 1998 jeep cherokee
Fan relay is a good one for that and where I would start. Usually the cheapest to. But the next thing could be the fan switch.
SOURCE: Radiator fan will not turn off in my 2000 Jeep Grand Cherokee
usually the engine relay or cooling fan relay..!
SOURCE: radiator fan motor on 2003 Jeep Grand Cherokee
I hope that you haven't went out and bought a whole new assembly due to the other poster's response. Yes you can just replace the motor otherwise why would you be able to buy the motors separately. There's usually 3 bolts that hold the fan shroud in that you have to remove along with the electrical plug. It takes some manipulation to get the entire fan/shroud assembly out (it helps to have someone underneath the vehicle guiding it) but once out you will see a clip over the top of the fan. It's kind of a challenge to get off but using a hammer and a flat head screwdriver you can work it off. Be aware that you have to put the clip back on so don't pry it off and ruin it....just kind of chisel it off. Once off, the fan blade comes off with a little effort. There's your exposed motor. Take off the 3 bolts and pull out the wires and replace it with your new motor. I hope this helps others....I couldn't find this information anywhere and figured it out along the way.
