I'm installing a Clarion NZ503 head unit with the THD 309 HD radio tuner. both have antennas. Do I need to have 2 antennas/
I am not sure.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
SOURCE: I just install new Clarion BTL370 in the Clarion
A few things to check...
Make sure the receiver is set to "tel sw" or something similar in the menu. From there, you should be able to set the call to the left or right speaker. Make sure you set the headset to the same side.
Another thing to check, make a call and get connected through the headset. Now wait a few seconds and push a button on the phone to power the backlight. If it is wired correctly, you should see the "connected" timer on your phone keep time. If it appears that you are connected, the problem is most likely in the settings.
Also, if nothing else works, make sure that you have the accessory wire(should be red on the BLT370) connected to the right wires. All the other wires will power it on even if this wire is not connected correctly.
SOURCE: need to install my clarion vrx755vd, but have no
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
orange/white illumination
brown phone interrupt
grass green connect to earth if u want to watch dvd's whilst you drive
rate pls
SOURCE: in need a wiring diagram for a clarion vrx745vd
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
