SOURCE: LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
SOURCE: help using 8gb microsdhc card for the lg vu
the vu isnt compatible with the 8,try the 4 or 2.
SOURCE: Can't find passkey for bluetooth. (0000 won't work)
hey ! you cant give random pass keys..you ll have to provide a pass key to the device to which you are trying to pair with..and that pass key must be entered so that your other device is safe..! so you provide your other device with a pass key ..then try..ok
SOURCE: can't bluetooth connect mac book with VU LG CU920
you create the passcode, then your computer will ask for the passcode and you type the same thing in, it doesnt matter what passcode it is, as long as it matches.
