Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
What is gas to oil mix ratio on weedeater string trimmer
What is mix ratio
    New Friend:
  • 18 Answers
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Posted on Sep 28, 2014
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: where can you purchase replacement weedeater
You do not mention the model number of your trimmer. Poulan makes trimmers with two different size strings .093 and .080 both should be available at your local Walmart or Sears as they both sell the Poulan line of trimmers. Read your manual that came with the trimmer it will give you the proper size you need or post the model number here and I'll let you know the size you need. I hope this helps!
Posted on Aug 03, 2009
lwjackn
  • 10 Answers
SOURCE: What is the oil to gas mix? Paulan xt-200
Poulan motors usually use a 40:1 mix ratio.
That is 3.2 oz of 2-cycle oil to 1 Gallon (128 oz) of gas.
Be sure to not use gas with more than 10% Ethanol.
Posted on Jun 09, 2010
Robert Babcock
  • 3 Answers
SOURCE: trimmer starts but the spool wont turn anymore
you're trimmer could have one of two problems, One, if it has a clutch on the engine,( the way you would tell is if it doesn't spin when it idles. it has a clutch) Two, your trimmer would spin all the time, they use round flexable cables stamped square on both ends, which fit into square sockets one at the engine one at the trimmer head, so you're problem is either a worn out clutch, or, the cable is broken, or, one maybe both sockets have become rounded out. I hope this helps you out. Bob
Posted on Aug 01, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: what is the fuel to oil mixture ratio for my gas
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Posted on Sep 08, 2010
slick45836
Ricky Lytle
  • 61 Answers
SOURCE: What ratio of oil and gas do I mix together? How
If you bought it used, you can bet that they didn't run it out of fuel before they stored it, so the gas evapoated out of the carb and all that was left was oil, so mix your fuel 8 to one eight parts gas and one part oil, you'll have to hit the primer botton several times.
Posted on Jun 16, 2011
What is the oil to fuel ratio for a cub cadet trimer/brush cutter?
The exact mix ratio for Cub Cadet trimmers varies, depending upon the exact model. Cub Cadet's ST 228 2-cycle trimmer model uses a mix of 2.6 fluid ounces of 2-cycle oil blended with 1 gallon of unleaded gasoline or a 50-to-1 ratio. This equates to 20 milliliters of 2-cycle oil to 1 liter of gas. The Cub Cadet BC 210, on the other hand, requires a mix ratio of 40 to 1, or 3.2 fluid ounces of 2-cycle engine oil to 1 gallon of unleaded gasoline
Jun 22, 2018 | Cub Cadet Garden
Petrol & Oil mix - one third of oil to 1 gallon = what in litres
You need to go by the oil to gas ratio. 1/3rd what?
Google 50:1 (or whatever) mix in litres
and you will find this
Google 50 1 mix in litres Google Search
Mixing ratios. For a mixing ratio of 1 : 50 you need 5 litres of high-octane gas and 0.10 litres (100 ml) of STIHL two-stroke oil.
Dec 03, 2017 | Garden
Gas to oil mixture
Gas to oil ratio is a function of the oil you are using. Mix according to what the oil says not what the manufacturer of the engine says. Those ratios could/may be the same. IF you mix 16:1 oil (do they even sell that anymore ?) at a 50:1 ratio it will destroy the engine. There will be no problems at 16:1 as the oil recommends.
I have used 100:1 Optimoil (?) when I can find it instead of the recommended 48:1 of my 2cycle. No problems.
Mix the oil in ratio the oil manufacturer says to mix.
Sep 07, 2017 | Garden
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
How do mix proseal at a ratio of100x10
That is a 10:1 ratio
10oz to 1oz
10gal to 1gal
10ml to 1ml
etc
Aug 23, 2014 | Garden
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Need to make 50:1 ratio mix. what i have on hand is the poulin 3.2 fluid ounce that makes 1 gallon at 40:1. how many ounces of this mix would need to be used to achieve the 50:1 mix ratio.
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
Dec 28, 2010 | Poulan 2-Stroke Engine Oil - 24 Pack
Gas/oil ratio for a Homlite yard broom UT 08026H blower
It's 40:1 but there are oil mixes out there now that you can buy that you mix with one gallon of gas and then it is safe for all 2-cycle engines...a real plus if you own multiple units with different mix ratios.
Jan 10, 2010 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
514 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
