Coffee Makers & Espresso Machines Logo
A
Anonymous Posted on Sep 18, 2014
How do i clean a keurig coffee maker?
Someone said vinegar would work. If it is vinegar, then what kind and how much does it cost?
mauricembm
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 19, 2014
mauricembm
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
782
Points
12
Use white vinegar only. Do NOT use wine vinegar, flavored vinegar, balsamic vinegar, etc. Buy the cheapest one that you find in a supermarket. Fill the reservoir up halfway and run it through until empty. Then flush with plain water with TWO (2) full reservoirs of plain tap water.
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Apr 04, 2009
SOURCE: funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
sonofbeach
  • 18 Answers
  • Posted on May 21, 2009
SOURCE: Keurig B50
I have the same problem, but overcame it with a reusable K-cup. They are available online and at some national chain stores for about $15.00. It's a not as convenient as K-cups, but better than throwing out a $150 coffee maker.
Anonymous
  • 10865 Answers
  • Posted on May 23, 2010
SOURCE: Keurig Coffee Maker barely brewing any coffee
Hello. It is time to descale your machine. To do this, go to this link and read how. http://www.coffeecow.com/PublicPages/ArticleInfo.aspx?ArticleID=18
Anonymous
  • 43501 Answers
  • Posted on Feb 26, 2011
SOURCE: Our Special Edition B60 Keurig
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Anonymous
  • 43501 Answers
  • Posted on Apr 02, 2011
SOURCE: I cleaned my Keurig with vinegar. Ever since the
Check out this tip about how to descale your Keurig coffee brewer
How toDescale your Keurig Coffee Brewer
heatman101
I cleaned my keurig and now it doesn't work?
How did you clean your keurig? The way that I do it is fill the tank up with vinegar and run it through. The way that you might have washed it may have clogged it up. Using the vinegar will clean and unclog the machine.
2answers
Can i use nuvera coffee cleaner keurig coffee maker
We use a 75% vinegar and 25 % water. Then we rinse it twice with plain water. Also remove the little K/cup holder and clean it good and then replace in the machine. Works for us!
How to descale keurig elite 40 coffee maker with vinigar
Unfortunately you will need to use vinegar. The acetic acid in vinegar is strong enough to clean most brewing machines.
Use distilled white vinegar.
How to clean keurig
It might be time to clean your keurig. Fill the water tank with vinegar and run through about 5-6 glasses leaving time in between to let the vinegar clean. After running all of the vinegar through it should be brewing regularly again.
How to clean keurig coffee maker
Keurig coffee maker isn't filling the cup as much as it used to
if you have not given it the vinegar cleaning, yet that solves most of the problems
check their website for the correct mixture of water and vinegar
6helpful
2answers
How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
5helpful
How to clean the Keurig coffee maker.
fill the reservoir with distilled white vinegar and leave the brewer on for 4 hours (leaving the auto off option OFF). after the 4 hours, run the entire vinegar filled reservoir through the machine.
refill with water and repeat twice. your machine is now cleaned and descaled.
4helpful
B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
