How do I remove an app from my apple iphone 5c
There are 4 ways you can remove an app from iPhone 5C. Just look below.
Method 1. Delete Apps Directly from the Home Screen
Method 2. Delete Apps from Settings
Method 3. Delete Apps from iPhone in Batch
Method 4. Delete iPhone Apps from iTunes
I will show you the easiest way to do that.
It is the easiest and quickest way to delete apps from iPhone directly. All you need to do is go to the main screen. If you have saved a lot of apps in your iPhone, and want to delete them, you can directly delete them on your iPhone. The steps below will show you how to delete apps from iPhone directly.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
To delete an app, tap the X, then tap Delete in the dialog the displays. Note that doing so deletes not only the app, but also all of its data. So if you think you'll need an app again soon, and you have stored data, settings or completed levels for it, you might want to think twice before tapping that X.
For more details of other methods, check: Four Methods to Delete Apps from iPhone Easily
You can remove third-party apps by:
You cannot remove built-in apps such as Messages, FaceTime, AppStore, etc.
SOURCE: What colors does the Apple iPhone 5c come in?
The iPhone 5c comes in 5 very bright colors. You have the choice between green, white, pink, blue and yellow.
SOURCE: Apple Iphone 3G Apps
The user name and password that is asked for is the same one you set up in itunes when you appled for an account.. the user name is the e-mail address you used for the account and the password you associated with it so if you have not done so set up an account with itunes first.
If you have already got said account then double check to make sure you are entering the correct password the e-mail you used should be already visible in the dialogue box that has popped up asking for the password
SOURCE: my apple iphone froze on the apple logo
Connect your phone to the computer and open iTunes. Hold both the home key and the power button until the iPhone turns off. Continue to hold them both for 5 more seconds. Release the power button but continue to hold the home button for 10 - 15 more seconds. I tunes should detect the phone in DFU mode. Restore firmware from this mode.
SOURCE: Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "the last option helped alot thanks x"
SOURCE: How's the new Apple iPhone 5C different from the
The new Apple iPhone 5C is very similar to the iPhone 5 both in software and hardware. The real difference between the two is their appearance.
Differently from the older iPhones 4s and 5, and the newer iPhone 5S, made of alluminium and glass, the iPhone 5C has an outside structure of polycarbonate, which makes the phone more resistant and similar to other plastic-based phones. Another big change was the color range. The iPhone 5C comes in 5 different very bright colors, only seen on iPods before.
