Needle position does only go up when button "up or down" is pressed
I just took a look at your user's manual (I recommend you go to the Singer site and download it--it's free), and on page 20, it says that the top button of the set of three buttons above the needle shaft is the needle up/down button. If you press it when the machine is NOT sewing, it will reset it to stopping with the needle UP instead of DOWN. In other words, it resets the needle's default position, but you must do that when it isn't sewing anything.
SOURCE: motor is running but not sewing, not pulling the fabric through
either your clutch is disengaged for bobbin winding mode or its got a drive issue internally.
Check that the clutch has been reenaged after winding a bobbin; somtimes this is a button inside the flywheel, a knob inside the flywheel you loosen (towards you) and tighten (away from you) to operate.
Or it may be just flicking the bobbin winding spindle which deactivates the main needle and feed dog drive.
If you don't have a manual to check the clutch instructions for your machine then visit the Singer website as most manuals are there free to download. http://www.singerco.com/accessories/instruction-manuals, type in your 4 digit model number and click "search" then wait for the page, when you see a red and white box "free download" click on that to open the pdf file.
If you are sure the clutch is reengaged, and there is still no movement, then you may need to take it for repair.
