103 most popular error on DLink Modems and Routers.Error occurs when your computer or router is not able to find the internet connection. Reason behind settings of the modem or router.
Try to use :
"https" instead of "http" in the URLs.
Check Firewall is not blocking your internet connections.
carry out the resetting of the dlink router then use lan cable to gain access to dlink router, set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Press in and hold the reset button on the back of the router. Connect directly with a patch cable and configure your wireless settings by typing 192.168.0.1 in address bar. Download the manual here: http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
Can you get a pc to connect to the internet? If you can, what IP address does HUGHES assign? If it is in the range of 192.168.0.X then change the DEFAULT GATEWAY address of the router to something like 192.168.10.1 (out of the box it should be set to 192.168.0.1)
