Connect Onkyo Soundbar to Panasonic Plasma TV
SOURCE: tv soundbar with a 5.1 receiver
The Onkyo has a center channel pre-out that you can connect the sound bar to. How does the sound bar connect to the TV? Is it two rca jacks, 1 red and 1 white or black? What brand and model is the sound bar?
SOURCE: how do i connect a soundbar to this receiver? My
Hi there, use your pre-outs, you shuld have pre-outs for all channels, I think the soundbar is supposed to create its own surround effect so I would connect it to the front two channels
SOURCE: I have an Onkyo TX-DS575
HD Video FROM your TV???? Video goes TO the TV and gets there either via direct tuning of an HD air station or from a Cable?SAT box, BluRay player... The unidentified TV's manual should cover that.
The Onkyo's manual covers most of the rest.
My $.02...
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption. The separation of audio and video inputs and outputs on a device is what allows and ENCOURAGES the routing of each signal to the BEST electronics that can process it. Example: your TV does not have the best speakers in the room so why send it any high-end audio?
If the sound actually comes from an external source treat that source like any other hi-end audio component and attach its highest quality audio directly to the receiver according to ITS manual. The separation of audio and video inputs and outputs on a device is what allows and encourages the direction of each signal to the BEST electronics that can process it.
Testimonial: "Thanks gotcha!"
