Hinges locked and unable to unlock to reinstall oven door. .
The bottom locks to the top. Take a look at the video in the link below and you'll see what I'm talking about. It's not your microwave oven, but the door hinge is the same. https://bakingreview.com/oster-1-4-cubic-foot-digital-microwave-oven
SOURCE: put back smeg oven door
http://www.smeg-service.co.uk/support/index.php?a=3
Here is a link to the pdf file that you can download from the internet for instructions about your door.
Just copy and paste the link into your browser window and click.
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
SOURCE: can't put the door back on VIKING oven
should be a clip on each side of the door. hold them in as you slide the door back on.
SOURCE: Brand new whirlpool built-in oven.This is a 24
This problem is solved...tech ordered a new pair of hinges.Thanks
SOURCE: How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
