Hi, Im trying to install 2 printers on my PC.
Running XP SP2, printers are both Canons, MPC600f (multifunction centre) & a LBP5000 color laser.
I've successfully installed the LBP5000 but when I attach the MPC600f it can't find it.
I've connected both by USB2.0 and I've lost the install software for the MPC600f, but downloaded the drivers from web.
Problem is it doesn't see the MPC600f when I plug it in.
looking for step by step instructions.
Kill it
Kill it
Try canon usa - the model name there is F50
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=6324
Xp sp2 changes a file in windows that is needed by the canon driver. there is a patch available to fix this. I haven't tried it yet as the printer belongs to a friend. Patch and latest driver available from page below.
http://www.canon.com.au/products/multifunctionals/multifunctional_colour_bubble_jet/imageclass_mpc600f_drivers.aspx
Good luck.
how do you instal from the downloaded file? i cant get it to work either
have exactly the same problem, cannot install it neither with usb nor with lpt. system does not see anything: the printer, the fax and the scanner. did you already solve the problem ?
Same problem here with MultiPass F50
I can not install my printer canon multpass f50. the computer can not find it.
I downloaded updated software (including driver) for the Canon MP80 (an older multipass which is still working great) and removed the previous installation prior to update. Now, the software won't install (even the forced installation), plug and play doesn't recognize the printer at all, and, if I try to install the printer manually with the Windows "install printer," the MP80 isn't even on the drop-down list of printers manufactured by Canon. The printer is working fine, except that now it is no longer connected to the computer. This is a convenient way to force me to buy a new printer even though there is nothing wrong with this one.
i need the drive for canon smaertbase600f
Similar problem with Canon MultiPass F50. Downloaded the driver and patch for the XP; using USB port. Message--cannot find printer. Also, after installation, message says installation is incomplete. Have repeated process a number of times, following Canon instructions.
http://www.canon.com.au/products/multifu... no longer available
