Power Washer 1850 PSI Electric Logo
A
Anonymous Posted on Sep 17, 2014
MY 1850 PSI POWER WASHER WON'T START UP. As fast as the motor started, it shut down. And there is still power. What is the problem?
As fast as the motor started, it shut down on my 1850 PSI PRESSURE WASHER. And there is still power. What is the problem? This is the 1st time it's being used this year.
Hotsy Equipment Company - Cincinnnati
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Nov 26, 2014
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
8512
Points
17
Probably a clogged carb from sitting all winter with fuel it it.
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
What would cause 2.7 motor to shut down and won't
did the timing belt let go?sounds like it
Craftsman 1800 psi power washer won't start. Help! Thanks.
Try a new unloader valve,if it is stuck the motor can.t overcome the pump and will either die or blow a breaker.
May 10, 2010 • Garden
2answers
Can't start my coleman 1850 generator
Need more info,
Does it turn over??
Does it have spark??
Does it have fresh petrol??
2answers
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
1helpful
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
Top Power Washer Garden Experts
Paul Bade
Larry Ng
Larry Ng
Steve Pack
Steve Pack
Are you a Power Washer Garden Expert? Answer questions, earn points and help others
