you cant,call your dealer,your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.
Parts stores sell an inexpensive little piece called a quick connect fitting tool. It slips inside the quick connect fitting and releases it so you can pull it apart. If you tell them at the store it is for a heater hose fitting for Expeditions, they should have the right sized one in stock. The quick connect fittings have many sizes and applications.
I had the same problem. I took the truck into the dealer and there was a computer software upgrade that needed to be installed that altered the shift points in the transmission. After that 10 minute fix, I have had no other issues.
