When the machine stopped working, came the message instructing to power off and on. If the problem continues I should contact a technician for E000000
That error code means your Canon failed to warmup properly. Could be a bad Fixing assembly. Sometimes it is possible to just reset the code and then you may continue to use the machine. Based on the error code you provided, I assume you have a Canon but you need to post the model number to receive more detailed advice.
SOURCE: E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
SOURCE: Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
SOURCE: I have an error message - E000000-0000. What's up
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: error code E000000-0001
Hello nelco9,I can help you clear the code easy enough. But there is a strong probability the code will come back almost immedietly.Copiers use high heat and pressure to bond the toner to the paper.It is of course critical to accurately monitor this high temp as to insure against fire.The code E0000000-001 means that for any number of reasons the copier did not or could not reliably monitor this temp.Now, something as simple as a momentary variation in the power to the plug the device is plugged into can cause this code as the plug voltage and/or frequency is sufficient to interfere with the copier's ability to track the temp, so lets hope for the best.Trust me there are so many fail safes involved in this process that the copier will properly shut down if the problem is serious.Ok,locate the'ADDITIONAL FUNCTIONS" button on the op panel.It is just to the right of the 9 key pad.Press it, let go, then the numbers 2&8 simaltaneously,let go, then ADDITIONAL FUNCTIONS again.You will see a new screen.Press "copier". Tabs appear at the top.Press the "function" button.New screen again.Press "clear".New screen.Press "ERR" .Press "OK" in the lower right corner.Now if you TRULY know where the main power switch is (right rear of copier about halfway down) then power the copier off.If in doubt simply unplug the copier.When you turn it back on the copier will attemt to start up as normal.If it does then congrats !!.If it fails you will need a new fusing unit which can run as high as $800. I truly hope I have helped you.Take care.
SOURCE: turn the main power switch(on the main unit's
check the power supply first. is there any voltage fluctuations? Go to service mode. Addl. function>2&8>Addl. function> select copier. function>clear>err>ok. switch off the machine, wait for 15 minutes & turn on
