Trying to set up an apple,box when away from home where the Internet provider is Zebra Want to,use my netflix account
SOURCE: how do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
SOURCE: want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
SOURCE: Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
SOURCE: Zebra Designer Pro Key
Zebra Designer PRO is an additional charge that must be purchased separately.
