I need to know how to download pictures from my lg 800 g cellphone and downloading onto a dell inspiron laptop?
You can connect the Data cable/ Transfer cable provided along with the LG 800 g cellphone to your Dell Inspiron laptop or you can simply use Cloud features to send or upload videos/pictures etc.. .Moreover, PowerDVD 13/14 imply a good application for user with multiple devices by allowing them to share their priceless moment on the go.
You may want to connect the data cable/ transfer cable provided along with the LG 800 g cellphone to the Dell Inspiron laptop. Then simply use a copy- paste method from the phone to the laptop. This should help but if this doesn't help then let me know what happens.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
SOURCE: Getting a copy of the operating System cd for Dell Inspiron 6000
Dell not being provided with system operating disk aka Windows nor drivers disk needed for their systems. This always poses a problem when these people are advised to do a repair install or other system repair, only to discover that they have no disks. The normal solution recommended is to contact Dell support and ask for the disks.
Dell has a support site where you can order disks for your system as well as other important links to updated drivers. On the site Dell states:
Dell Customers can now request a set of backup discs containing the factory-installed operating system as well as the device drivers and utilities specific to your system.
Requests are limited to one (1) set of backup discs per system purchased.
The backup discs requested must match the operating system that was factory installed on the original order.
Please note that Dell will provide you the most up to date Resource disc available, containing the latest drivers and diagnostic tools currently being shipped on new systems. Due to the frequent updates, this Resource disc may not have all the drivers needed for your specific system, especially if it is over one (1) year old.
Complete details here.
Good Luck / Please dont for get to Vote.Thank you.
SOURCE: Dell inspiron 1200 recovery disk
If you are just wanting to restore the machine to a factory state you can follow these instructions according to the manual which can be found at http://support.dell.com/support/edocs/systems/ins2200/en/om/D88330a.pdf
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish restarting, and then
restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6–10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the
screens that appear, such as the End User License Agreement, are the same ones that
appeared the first time the computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
If you need the actual disk, you can check your warranty here http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen by entering your service tag from the side of the machine. If its in warranty you should be able to get a new set shipped to you.
If not, you can contact Dell here http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?c=us&l=en&s=gen and asking for information on replacement disc for your model.
I hope this helps. Please remember to rate this information.
Thanks
SOURCE: i need to download the sound card for my dell inspiron 6000
i found the sound driver that works on DELL INSPIRON 6000
It also works on:
Inspiron- 6000, 93000, 9200, 2200, 1200, XPS Gen 2
Latitude- D610, D810, 110L, D510, D410, X1
Precision- M20, M70
Computers- MXG051
This should help other Dell users as well.
ftp://ftp.dell.com/audio/R99254.EXE
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
SOURCE: dell inspiron 1525
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
