I need more ram for my laptop at least 4 gb my model number is PSL2XU-OOKOOF what am i looking for i thought it was for a pc2-5200 but i cant seem to find it anywhere
Hello, the memory part number is: KTT667D2/1G
I found this on 2 sites.
I found your laptop here: http://www.sparepartswarehouse.com/Toshiba,Satellite,L25,PSL2XU-00K00F,Laptop,Memory.aspx
I found more another option for memory on Toshiba's site: http://www.toshiba.com/us/accessory-finder?accFinderCat=Memory&part=%20PSL2XU-OOKOOF&stt1=Laptop%20PCs&stt2=All&sttSeries=All&stt3=All&x=134&y=17&accFinderCatFriendlyName=Memory
I hope this helps you!
SOURCE: Hi I have a Toshiba laptop model no.psl2xu-ookoof
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
