Washing Machines Logo
A
Anonymous Posted on Sep 16, 2014
My whirlpool frontload wfw8300sw05 washer stops and shuts down between drain/rinse and spin cycle when in any wash cycle .It will complete the rinse/spin cycle.Could it be the electronic control board
The washer will spin and complete the cycle when you select the drain/spin or rinse/spin cycles.
Siyabonga Mzimela
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 173 Answers
  • Posted on Sep 17, 2014
Siyabonga Mzimela
Expert
Level 2:
New Friend:
Cheetah:
Answers
173
Questions
0
Helped
43047
Points
247
Pcboard mulfunctioning
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jul 22, 2008
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Anonymous
  • Posted on Aug 31, 2008
SOURCE: will not drain after the wash cycle, will not enter the rinse cycle
It sounds like the lid switch is bad.Does it act as if the lid is open even when closed? A common problem is that its mounting method fails (breaks off) after some time. Quick way to test is:
Find the plastic striker in the lid and under matching hole in the washer's top you should be able to find this switch. Try to operate (close) that switch with your finger or a screw driver and operate the washer while holding it down. If now it works, the switch is the culprit. Available on-line around $30.
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Sep 21, 2008
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Anonymous
  • 102 Answers
  • Posted on Apr 02, 2009
SOURCE: Kenmore HE2 Frontload Washer will Not go into spin cycle
Could be that you have something in the pump. Remove the bottom panel by removing 3 screws and you will see a round cap facing you in the center of the washer at the bottom. there will be alot of excess water behind this cap so get ready with plenty of towels. Unscrew the cap as you would the gas cap on your car and all the water in the lines and in the machine will come out here. Inside here you may find a number of things. Some of the things I have pulled from them are ...coins, socks, pencils, underwear, underwires to bras. The list goes on and on. Or you may not be using "he" detergent. Use only "he" powder detergent. Use vegetable oil to remove excessive sudds build up then use 2 cups of vinegar to clean the machine on whitest whites seting.
Anonymous
  • 9 Answers
  • Posted on Apr 20, 2009
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
1helpful
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
I have an LG WM1814CW wash machine that shuts itself down in mid cycle. No codes given??
We had a problem like this with our whirlpool duet washer and we found out that the drain filter was restricted by of all things one of our kids socks. I cleaned out the filter and have not had the problem again so far and its been about a year now. The filter on ours was behind a little door that screws open and is in the drain line.
4helpful
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
2helpful
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
6helpful
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
3answers
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Top Washing Machines Experts
john h
