Computers & Internet Logo
A
Anonymous Posted on Sep 16, 2014
How do i switch on my internal modem within my advent laptop.
Laptop will not link by internal modem to the server.
stephen Adams
Level 3:
  • Advent Master 2,219 Answers
  • Posted on Feb 09, 2015
stephen Adams
Advent Master
Level 3:
Answers
2219
Questions
0
Helped
355193
Points
22262
Go to Control Panel.
Got to Device Manager
Select modem in list of devices.
Pick "Enable"
2 Related Answers
Anonymous
  • 258 Answers
  • Posted on Apr 04, 2010
SOURCE: battery does not seem to hold charge
Sounds like your battery is dying.
Laptops should not be run on mains power all the time, it kills the battery. Should be run on battery until battery warning occurs, then plug in to recharge.
You'll need a new battery at this stage.
Testimonial: "Thought this might have been the problem. Thanks for the confirmation."
Anonymous
  • 670 Answers
  • Posted on Apr 12, 2011
SOURCE: how do i switch
There should be a software to manage your internal webcam it varies depending on the brand and the model of your computer. Go to All programs and then look for the software that has something to do with the camera in there.
you can also use skype or yahoo messenger to open them.
1helpful
How can I change the password in a HN7000s IPS modem
Dear Jacques,
Here is a link to the for Hughes HN 7000S IPS Satellite Cable Modem Receiver for the manual with the information you are seeking. http://www.cpe-labs.com/PDFs/HughesNet/DW6000CustomerGuide.pdf
On page (16) sixteen within the PDF identifies all the contact numbers you will need to receive world wide help to assist you with your process.
On page (17) System Control Center explains in detail the internal web server that answers to the address for the DW6000 & DW7000. For the DW7000 follow this link
http://192.168.0.1/. Then to http://www.systemcontrolcenter.com/ .
On page (19) is the portal for your Direct way devices at this link
myhughesnet com .
On page (20) you will find, " How to change your email account password".
At page (37) Broadband Reports.com offers a satellite forum at this link
What browser proxy settings should use with the DW6000 Satellite Forum FAQ...
In conclusion, on the last page of the report title, Direcway Service Plans Ku Band DW7000 NTI,
you are offered a technical support telephone number to contact. It is 1-866-DIRECWAY.
Fare. Well.
Does the advent 7039 have WiFi built in. If not how can I connect my mobile phone and use. T*at as modem to get laptop online
According to this link it does have built-in Wifi. Check here: http://www.uktsupport.co.uk/advent/laptop/7039.htm
There is a link to download the user guide as well so you can figure out how to turn the Wifi on and off. Your Wifi adapter might be disabled or turned off or need drivers installed in order to work. Download the user guide and necessary drivers using a working computer or laptop. The user guide should show you how to troubleshoot why your laptop Wifi is not working...
1helpful
Can't locate webcam
You didn't post the Advent Model or the OS you are using? Internal or External Webcam? If Internal, Your Laptop came with Webcam software, without the model Advent I would not know? All I can do is point you to Advent Laptop Support, perhaps a User Manual: http://www.adventcomputers.co.uk/product-support
Hi. I have a Motorola SB 6121 DOCSIS 3.0 cable modem. When I have a direct connectivity with this modem to the laptop with an ethernet, it works fine. But when I connect it to the Linksys wireless router,...
what is the ip address of the cable modem ?
when connected directly to the modem can you do ipconfig in dos command window and find out the gateway ip address listed.
This has to be the gateway ip address in the wi fi router.
turn of DCHP server in the WI FI router and make its ip address one more than the cable modem ip address.
make sure subnet mask is the same in both devices
Make sure DHCP server in Modem has leases above 20 to allow other devices to use 1 - 19 .
eg 10.0.0.1 or 192.168.0.1 for cable modem ip address internally.
make wi fi router 10.0.0.2 or 192.168.0.2 depends on the ip address of modem ?
Gateway address of 10.0.0.1 or 192.168.0.1 depends on the ip address of modem ?
dhcp server leases from 10.0.0.21 to 10.0.0.254 depends on ip address of modem ?
How do i switch my mic on my advent laptop
hello jamesmstead8,
here i will suggest you a link for all your laptop problems,
http://www.uktsupport.co.uk/advent/laptop/lapmod2.htm
Go there, Find your model there is a list of shortcut keys givem there.
Enjoy
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
1helpful
3answers
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
2answers
Have an ibm think pad trying to link it to hppsc1317 all in one printer.laptop has driver installed in it which seemscorrupted it only installs to 96% and keeps trying. carnt delete printer programme it...
Lucky you help is on the way. First of all I need to know th Operateing System on te Think pad. Next I need to know the Manufacturer and model of printer. Once I have that information I can help you.
All The Best,
RCF
Top Advent Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
