Question about Magic Chef Microwave Ovens
My microwave oven buzzes when plugged in
Model #MCD131ST Stainless countertop microwave 1100 Watts. when plugged in the unit buzzes. It happens when in use of not. It is only 14 months old. Any suggestions on what might be causing this. Food heats when in use.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 173 Answers
Normal it buzz when you left yo food inside even its fin7shing warming or wateva youre doing, but if its just buzz you can disconect it if you want or take it to the technician
Posted on Sep 17, 2014
Testimonial: "Good suggestions but I had already arrived at these conclusions before seeking additional. Appreciate hearing from you"
Anonymous
SOURCE:
Anonymous
SOURCE: Microwave won't heat food.
My Whirlpool microwave, over the stove, stopped working when my son used it to heat his food and a heavy sound came out, like something exploded in it. When I check it, there was nothing broke. Everything works fine except that it does not heat. I will appreciate any help
Nate
Posted on Nov 09, 2008
Anonymous
  • 706 Answers
SOURCE: MAYTAG MMV4205BAS Running but not heating
If the food in the cooking compartment is not heating at all, then you may have one of several components related to microwave energy generation that have failed or became disconnected internally.
Magnetron Tube, HV Capacitor, Filament Transformer or any number of sensors that disable power to the system. The control board could also cause the system to noty function correctly.. You wanted general inputs.. there ya go.. LOL
Not sure I told you anything you didn't already know but you should ask the tech what he did after he gets it going...
Regards,
Rick
Posted on Nov 28, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp microwave oven model r-1440 runs, but doesn't heat food
Assuming your inside light and turntable come on when you try to microwave, with the symptoms you have, I would most strongly suspect a bad magnetron or a loose and possibly corroded connection on the magnetron's terminal.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it'sprobably okay)
http://www.gallawa.com/microtech/mag_test.html
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Posted on Feb 08, 2009
Anonymous
built in 3/94 is it worth fixing how much for magetron
Posted on Feb 12, 2009
dennis bullard
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
Model:OGD21102 MICROWAVE IS NOT ALLOWWING ME TO COOK MY FOOD. The microwave says Food and that is it. Will not heat, I can push a time and it says Food. What should I do.
if opening and closing the door fails to clear the fault , then your door switch's have a fault in them , this is not too uncommon on microwaves , as most of them have three separate door switches ,(its a safety thing ) as the last thing in the world you'd want to happen is running it with the door open . make sure the door seals properly and there's nothing down in the cracks (even the hinge side) that keeping it from closing properly , I once had a pealing factory label do this , so it doesn't take much to trip the door switch
Feb 09, 2016 | Oster OGD21102 Black Countertop Microwave...
How to set up the clock?
No sweat, really easy. press clock button once for 12hr twice for military time, then enter time, press clock button again.
Magic Chef MCD1611ST Instruction Manual Controls Setting The Clock Time...
Mar 31, 2015 | Magic Chef MCD1611ST Stainless Steel...
I have a 12yo Sharp r-430cs microwave. The LED is not displaying all the "lights" in the numbers/alpha readouts. It is missing a lot more of the readout than it is showing. Everything else is working
Go to Sharp's website and check availability of the clock/timer readout board. Being that old you may not be successful, but it;s worth a try.
Oct 21, 2014 | Sharp Microwave Ovens
Kenmore elite microwave 79203 buzzes when off
It sounds like you have a shorted cook relay on your control circuit board.
That can usually be repaired more economically than replacing the circuit board.
Jan 09, 2013 | Kenmore 79203 Elite Stainless Steel 2.0...
No power to unit. Internal fuse ok. Power ok to plug
It sounds like you have a short in the keypad controller system, there is a microprocessor board mounted behind the the keypad that control vital areas of the microwave's operation. I suggest appliance technician to check out the systems hardware and the rest of the oven.
Jan 31, 2011 | Kenmore 80603 Stainless Steel 1100 Watts...
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Jun 21, 2009 | Panasonic NN-S433 1100 Watts Microwave...
Buzzing noise and flashing
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
Remember... always cover your food...
Geno
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
120 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
