After washing there are brown specs on otherwise clean laundry
Run the washing machine with a cleaner compound like http://www.target.com/p/tide-high-efficiency-washing-machine-cleaner-5-count/-/A-14230069
Also the pump can be cleaned by undoing the tap at the bottom front of the washer. First make sure the drain tube has been pulled out to empty residual water in a container. Then unscrew the tap and filter to clear any dirt and items stuck in it.
Check the manual at this site.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMD740PUKRE_19509388200.pdf
SOURCE: Our washing machine will not pump out and we have lost the manual
it should be at the back of the machine were the pipe for dirty water comes out there is a panel you can take off at the bottom of the machine when it is off you should see the moter and the pump were the pump is you and take off the black sump asmbaly and the filter should be there. hope this helps.
SOURCE: Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
SOURCE: Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
SOURCE: My Hotpoint Ultima WMD 960 displays
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
SOURCE: Dirt and oil spots on laundry
The rear seal and the rear waher drum bearing is defective, this allows grease to get into the washer and that is what is getting on the clothes
