I have replaced the seat switch and the switch on the brake. I can start it sometimes, but then when I let the brake off, it dies. How do I bypass these two switches? I assume they're connected
SOURCE: release brake engine dies engage blades engine dies
there is a saftey switch on the deck that has shorted out need to replace
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
SOURCE: How do I bypass my seat safety switch on my
It's not a good idea. But if you must, it's just a switch. If it has two wires, cut them from the switch and connect them together with a wire nut. If it has only one wire, then cut it from the switch, put a spade terminal on it, and connect it to the frame of the tractor.
replace the switch on the brake/clutch it is a dual switch so it can crank and still be bad
