Water is coming through the hose but not into the washer. we had a problem with a water main breaking near us and had to clean out all of our faucet screens but, I can't seem to find where it would be in the washer.
SOURCE: "nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
SOURCE: Washer leaking water from bottom
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
SOURCE: Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
SOURCE: The LF error message pops up on Bravos washer
might want to check screens in fill valve where hoses attach to machine
SOURCE: My Maytag Neptune FAV6800 washing machine
If you pull the power to the machine and water continues to flow then the water inlet valve is stuck open. You will need to replace the water inlet valve. The Service manual will step you thru the process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The water inlet valve is p/n 25001046 Substitution: 12002242 Water valve shop around for best price.
Is this Cold water inlet valve issue? If so and you only do Cold water wash/rinse like me you could switch the fill hose connections from hot to cold to hot at the faucet. Turn the hot water faucet valve off and select Warm/Warm temp selection and you will be filling with cold water wash/rinse. Maybe that would hold you over until you replace the Water Inlet Valve assembly.
You can check out your pressure switch transitions as I had this poster do for his issue at this link http://www.fixya.com/support/t5471295-washer_fills_water_begins_agitate_but
His issue seems to be a definite stuck pressure switch not water inlet valve such as yours. Check to make sure your pressure switch is OK by watching the fill point transitions as I mention in the post.
If you machine is a series 12 or above the Low and Mid fill pressure switch transitions will toggle at the same time. Series 12 and above us a 2 level pressure switch. Series 10 and 1 use a 3 level pressure switch.
Good Luck………….. D*ick
Testimonial: "Excellent advice, thank you!"
