I have a UNIVERSAL URC 11-1410 URC-1410 E131001 TV REMOTE Control but have lost the instructions for it. can you tell me how to program it ? many thanks.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electromedicals.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: kingavon remote control rc81s universal remote control
To program the Kingavon Home & Leisure 8 in 1 Remote Control RC81S:
SETUP by MANUAL SEARCH
A: Power on the device that you want to control. If it is a VCR, it must be inserterted with a tape. *(This works without a tape)*.
B: Press and hold [SET] key and press the device key (TV1 etc) at the same time.
C: The LED will be on at the moment. Then release the pressed keys.
D: Press the [POWER] key again, then release it. The remote control enters into Manual Search Mode and the LED keeps flashing.
E: Point the remote control to the device, and then press the [POWER] key. See if the device reacts or not. If it reacts, turn to step F. If not, repeat step E (press the [POWER]) every 1 Second.
F: Test other keys, if they do not work good enough, return to step A.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
