I have amodel rz4623 zero turn mower the belt is jumping a lot,replaced right deck puully front idler pilley same problem
SOURCE: deck removal
If memory serves me correctly it is just disconnecting the rods and I think there were a few large springs also. If you tear it down that far you may as well check pulley bearings too!
SOURCE: need a diagram for husqvarna model lth-130 mower deck belt
Here is a diagram I have found for you.
SOURCE: Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
