Craftsman 2700 PSI  Briggs Stratton Powered Pressure Washer Logo
A
Anonymous Posted on Sep 16, 2014
Pressure washer runs about 10 minutes then cuts off
When it cools for a few minutes it will start again
Pablo
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Sep 16, 2014
 Pablo
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
21901
Points
63
Could be low oil. Most motor turn off as a protection when the motor oil is low. Also, recently I have a similar problem, with a easy solution, just don't push the accelerator nob all the way, leave a 1/4 before reach full power. Apparently some times there is a bad calibration an make the carburetor over flow.
  • Pablo Sep 16, 2014
2 Related Answers
Mike Squire
  • 420 Answers
  • Posted on Jun 21, 2010
SOURCE: Engine runs for a few minutes then stalls...
It sounds like vapor lock or other lack of fuel. Premium gas will cause detonation and "may" have something to do with it. Drain the fuel the best you can and add regular fuel, after a couple minutes the engine should be burning mixed fuel and if the problem goes away you have fixed it, if not you obviously have other issues.
Anonymous
  • 16 Answers
  • Posted on Oct 17, 2012
SOURCE: I have a craftsman w/ honda model # 580752060 pressure washer. Started washing & after about 10 min. lost all pressure, no water comes from nozzle while engine runs. Cut off engine & nozzle s
you have a clog somewhere
My 2600 troy bilt pressure washer starts and pumps for about 4 minutes then it cuts off, my question is why ?
could be several things. replace the spark plug and try it again. if that don't fix the problem then the coil may need to be replaced. when an engine gets to operating temperature or hot some times the spark plug or coil will start breaking down and it will die. after it cools off it will start again.
Apr 07, 2016 • Garden
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
2answers
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 • Garden
Im having a problem keeping the motor running. it cuts off and will re-start easily and run in the choke mode? won't run in the normal mode until i cut it off and re-start. then it will run for about 5...
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
1helpful
I have a PW1686 power washer but it runs for a few minutes then cuts off. After a few minutes it starts again then goes through the cycle of on and off. Kindly tell me what are the possible causes.
The problem sounds internal (perhaps the temperature cut-off switch or the auto-start-stop switch). For safety and possibly warranty reasons, you should not open the case to investigate or repair; take the unit to your local service center.
1helpful
I have a union power pressure washer it runs for 10 minutes and then cuts off and wont work again, it still needs the choke on when the engine is warm and only runs for a few seconds
"it still needs the choke on when the engine is warm and only runs for a few seconds"
This sounds like a fuel problem such as the carb needs cleaning
Jun 16, 2009 • Garden
1helpful
Cuts off in warm weather after about 10 miles
Don't rule out fuel pump. Had a 95 do the same, ran great when cool in morning then when it got hot in afternoon, it would quit. Wait 15-20 minutes & go again, sometimes got me home, other times a few more miles until it cooled down again. Luckily I had access to a fuel pressure gauge. Cool in morning had 49 psi, when it quit, 2 psi. Wait 20 minutes, 49 psi again. If you can drive it around until it starts to act up then run into a repair shop for fuel pressure test it will confirm it. If not, they may need it all day to monitor the fuel pressure & confirm it is pump. If your a gambler, change it & fuel filter. One thing I did get was trouble codes indicating a lean mixture, due to starving for fuel. Have you cycled your key to retrieve any codes yet?
3helpful
2answers
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
