Question about Maytag MMV4205 Microwave Oven
I have a brand new Maytag Microwave MMV4205 that is making a loud buzzing to screeching noise when heating the food. Sometimes it is a low buzzing but most of the time it gets very loud. I had the owner of the store where I bought it come and check it out. He thinks it is a voltage problem and we need to put it on a separate circuit. However, my old one that this new one replaced never made a noise and it was plugged into the same outlet as the new one. I think the unit should be replaced. What do you think it could be?
SOURCE: Microwave causes GFCI on another circuit to trip
You may have a shorted High voltage component. Possibly a recttifier,aka, diode. This should only be replaced by an experienced repairman as an extremely high voltage shock potential exists.
Posted on May 27, 2008
SOURCE: My Maytag MMV4205 Microwave Oven runs but does not heat
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly
cheap fix, and the mag will cost more.
If you or someone you
know
decide to look into it, we have critical safety information and
disassembly information at our site, and our link is at our listing here on FixYa.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's
probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Posted on Dec 15, 2008
SOURCE: Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
Posted on May 15, 2009
SOURCE: My GE Profile Microwave/Convection Oven stopped working.
Chances are that the thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
This can happen when the magnetron overheats, either due to it's failing, or if the internal cooling fan is not working.
It may also that be the 15- or 20A ceramic line fuse or the oven cavity thermostat / thermal cutout / T.C.O. (whichever it uses) has opened.
There
should also be a "mini-manual" hidden inside the unit behind the
very
helpful
when troubleshooting & testing.
At
You can find
model number from the tag on the oven here.
You should be able to
get the fuse from a home center or local appliance parts store.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Posted on Jun 08, 2009
SOURCE: Maytag MMV5156AAS Microwave won't heat and has hum/buzz.
A failed diode isn't the most common failure, but it happens. And sometimes it's due to bad magnetron or a bad connection.
If the capacitor fails, it almost always shorts, which results in a blown fuse whenever you hit "Start" to run the microwave.
The magnetron on this model should have a 5-year warranty, in case that's relevant. Your owner's manual is here.
We have
the service / repair manual for this model and have uploaded it to our
site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
warnings first:
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/cap_test.html
There
should also be a "mini-manual" (tech sheet) hidden inside the unit
behind the
At
You can find
helpful exploded view diagrams and order parts here.
We're
thoughtful rating of our answer.
Posted on Jun 30, 2009
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Mar 02, 2011 | Maytag MMV4205 Microwave Oven
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 24, 2010 | Maytag MMV4205 Microwave Oven
May 18, 2010 | Maytag MMV4205 Microwave Oven
May 10, 2010 | Maytag MMV4205 Microwave Oven
Dec 12, 2009 | Maytag Appliances Over-the-Range Microwave...
Dec 02, 2009 | Maytag MMV4205 Microwave Oven
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
162 people viewed this question
