LG Studioworks 700S 17" CRT Monitor Logo
Posted on Jul 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tic tic sound with L.E.D blinking - LG Studioworks 700S 17" CRT Monitor
AlbertRoy
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 03, 2013
AlbertRoy
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
204
Points
Bad solutions dear.....
The Moniter Is Not Working.. No Fault With CPU>>>
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 212 Answers
  • Posted on Jul 03, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
212
Questions
Helped
39639
Points
590
Back side of your monitor PC to monitor cord was not plugged properly just plugged out from the monitor replug it it will be solved
dj_relly999
Level 2:
President:
  • Expert 4,070 Answers
dj_relly999
Expert
Level 2:
President:
Answers
4070
Questions
0
Helped
1065702
Points
207
It can be a broken monitor or a faulty video card. try replacing your video card. hope this helps
Hi the problem with my marantz sr770 amp is when I rise the volume the sound cut off & it make a sound like (tic-tic) inside,so pls help me!!!
It sounds like a shorted speaker or to many on one channel. It could also be a failed output device. I think the tic-tic is the overload safety cycling.
Tic tic tic sound when switced on no sound no video
:That sound usually means the power supply cannot start--due to an overload or overvoltage problem. Likely a few bad capacitors in feedback area or some short in horiz. area, possibly convergence chips if a tube set.
1helpful
I have a 2005 Jeep Wrangler Unlimited with 4.0 engine - when sitting over night (cold) engine start, after about 4-5 min after starting, I get this tic, tic,tic tic, from the engine, about half warmed up...
Lets try to verify were the sound is comming from. Injectors usually don't "TIC" they spray. But the best way to determine where the sound is comming from is to use a stethoscope. (sold in Auto zone), place it on the the noisy tin and listen.
What you describing sounds more like valves.
2answers
My western digital 320 gig external hard drive stopped working all of a sudden. it has not been physically damaged. when plugged in the lights just blinks.
you told that it has not been pysically damaged than why light just blinks ok first you see the cable is in good condition. next plugin you hard disk to your computer and listen if any kind of sound coming through your hard disk (sound is like tee tic) if the sound out comes like what i said some way it stuck or damaged let me know if it works
HELP ME PLEASE
its simple friend your ps2 version is old and it requieres updates or some sort of that... ps2 slim is new and has been updated thats why it doesnt make any noice try connection yours to the internet..
I've got a problem!! When I drive backwards, I can hear very well a strange sound, it's like ''tic tic tic tic tic..'' it's just during driving backwards!?!? Where is the fault? Someone knows this problem?...
There are several possibilities. It can be the speedometer cable, the brakes, or even the u-joints on the driveshaft.
The parts rub against their mating surfaces differently in reverse. Any play or dryness in the parts shows up. Sometimes it is good to catch these problems early because the wear is starting to get excessive.
Tic tic tic sound
Check for other problems. You might need to buy another FET as well. But this time don't put the FET back in until you make sure nothing can blow it.
Tic tic problems
check filtering capacitor of lot+B & replace it
Acer CRT Monitor with tic tac sound
1. horizontel transistor bad.
2. dry points on neck board.
3. cheak the power supply out put
4. LOT problem
3answers
CAR WONT START ON FORD FALCON AU (AUTO)
Check the voltage on your battery. When the battery is low, you will still have lights and what not but not enough juice to start the car. Check the condition of your battery cables especially your ground. If everything check out fine, your problem may be a bad starter or the solenoid. If you replace the starter, replace the solenoid with it. Be sure to check the cable from the starter solenoid to the starter.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
